Angel
August 23, 2018, 3:53am
1
Hi everyone,
Just another fast question. Is there any way of disabling Dynamic display when working with point clouds. It’s been hard to select certain areas in the point cloud that I’m working with when I cannot visually follow the points when rotating the view, as some of them disappear and appear again when I stop the view rotation.
BTW, I forgot to mention, this happens only when using a clipping plane in the view.
Thanks in advance.
Angel
August 23, 2018, 6:16am
2
I found a trick in case that it could be useful to anyone:
if you select the points in the pointcloud that you want to keep visible during the rotation, they don’t disappear.
P.S.: And extending it, if you select ANY part of the PC, all points remain visible during the rotation o.O (odd)
pascal
(Pascal Golay)
August 24, 2018, 4:42am
3
Hi Angel - are these large PCs? How large?(count)
Angel
August 24, 2018, 4:44am
4
226M points roughly for the complete one, but I chopped it in smaller chunks of about 1M points each.
Anyway, the weird thing is that it just happen when there is a clipping plane affecting the view and if I don’t select the PC.
@Angel ,
Would it be possible for you to send us one of these 1M PC chunks so that we can try to reproduce?
https://www.rhino3d.com/upload
Put david.eranen@mcneel.com in the recipient e-mail.
Thanks,
-David
Angel
August 24, 2018, 5:44am
6
@DavidEranen Done. You should have it in your inbox
Thanks for looking into this.
Hi @Angel ,
I got your file. Is the main problem that the point cloud turns into bounding boxes while rotating the view, or do individual points disappear as you rotate? I can’t seem to be able to get individual points to disappear.
In order to effectively disable dynamic display degradation you can go into Tools -> Options... -> View ->Dynamic redraw and set the Frames per second value to: 0.001
Tagging @stevebaer .
-David
Angel
August 24, 2018, 6:06am
8
Individual points disappear, and only when a clipping plane is affecting the view and I have no points in the point cloud selected.
If for some reason I have no clipping plane OR I select any point in the point cloud, all points remain visible.
I will try disabling Dynamic display and will let you know what happens.
Okay,
Please try disabling dynamic display degradation as I mentioned above.
Also, could you paste the information found in Help -> System Information...?
Thanks
-David
Angel
August 24, 2018, 6:22am
10
Rhino 6 SR7 2018-7-29 (Rhino 6, 6.7.18210.11281, Git hash:master @ f815aae129dfe2008152736625ca2dbd0036b29a)
Licence type: Commercial, build 2018-07-29
License details: Cloud Zoo. In use by: Angel Linares Garcia (AR-MA)
Windows 7 SP1 (Physical RAM: 64Gb)
Machine name: ARMA-32
Quadro K5200/PCIe/SSE2 (OpenGL ver:4.5.0 NVIDIA 386.01)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 12-2-2017
Driver Version: 22.21.13.8601
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Geometry Gym\Rhino3d\ggRhinoIFC.rhp “ggRhinoIFC” 1.6.49.0
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.7.18210.11281
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.4.1.0
Z:\001_CONTENT\002_PLUGINS\StereoView.rhp “StereoView”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.7.18210.11281
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.7.18210.11281
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.7.18210.11281
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.7.18210.11281
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.7.18210.11281
stevebaer
(Steve Baer)
August 24, 2018, 2:40pm
11
Is there a reason you chopped it into 226 clouds? Just curious
Angel
August 25, 2018, 1:29am
12
Hahahaha, @stevebaer I didn´t explian myself correctly, I only needed 33 PC. The rest was not relevant information. I chopped it to allow faster edition and to approach the job in a more “modular” way.
The problem was not very bad once I found a way to stop the behaviour (selecting some points). Anyway, is weird that the introduction of a clipping plane makes some points disappear when the view is rotated.
Angel
August 27, 2018, 4:31am
13
Hi @DavidEranen ,
I tried lowering the Dynamic redraw to 0.001 but it didn’t change the behaviour, just made the view rotation sort of slower.
