Point cloud - points disappear when using clipping plane
Hey forum
I have a problem where I try to print PDFs of a pointcloud (colored).
When using a clipping plane to get plan and sections, some of the points disappear.
This happens when activating the clipping plane.
As you can see on the screenshots, the points disappear when I pan around. But in the layout the points are missing the entire time - meaning I have missing points when printing PDF (I have tried differend PDF printers)
The point cloud is .E57 file
I’m using Rhino 6 SR35 2021-8-10 (Rhino 6, 6.35.21222.17001,
How can I fix this problem
Hi Tommy, Can you provide your SystemInfo as well? (type in the Rhino command line)
How many points in the cloud? (object property details, or the What command)
Thanks
Hey Japhy, here you go:
Systeminfo:
Rhino 6 SR35 2021-8-10 (Rhino 6, 6.35.21222.17001, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Commercial, build 2021-08-10
License details: Stand-Alone
Windows 10.0.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: DESKTOP-U9C494M
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 3-17-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.15
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2022
Driver Version: 30.0.15.1215
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.35.21222.17001
20 Pointclouds - totalling: 42.371.720 points
Point cloud with 2630531 points.
Point cloud with 1928442 points.
Point cloud with 1574321 points.
Point cloud with 1436482 points.
Point cloud with 2737939 points.
Point cloud with 2161315 points.
Point cloud with 2380669 points.
Point cloud with 2671338 points.
Point cloud with 2149191 points.
Point cloud with 2415157 points.
Point cloud with 2301749 points.
Point cloud with 2655446 points.
Point cloud with 2031181 points.
Point cloud with 2498372 points.
Point cloud with 2287851 points.
Point cloud with 2303836 points.
Point cloud with 1450883 points.
Point cloud with 1186146 points.
Point cloud with 856450 points.
Point cloud with 1822291 points.
Point cloud with 892130 points.
The problem is in plan and section(elevation) views - not perspective
Hej Tommy -
Do you also see the problem when you are only using one of these pointclouds, or is the problem related to the amount of either pointcloud objectes or total points?
Hej
The problem is still occuring when only one of the point clouds are shown
Hej Tommy -
I’m not able to reproduce this issue with a point cloud file that I have laying around.
Could you upload your file with only one of the point clouds to Rhino - Upload to Support - make sure to include the link to this thread in the comments field.
And, just to make sure, did you try a new file with only one of those point clouds? From that answer, it sounds like you might have turned off the layers or simply hid the other point clouds.
Hey Wim
Your assumption is correct - I did try again where i deleted the other pointclouds, but the problem still stands
Per you request I have uploaded a file containing the single pointcloud
Hi Tommy -
Thanks for that file.
I was about to give up but then managed to reproduce that behavior. Here, I had to exit Rhino and start it again to get it to display correctly again.
I tested the same workflow on Rhino 7 and this appears to have been fixed somewhere along the road. There won’t be any updates on Rhino 6 (all development and most bug fixing is only done in Rhino 8 at this point), so I’m afraid this is going to stay like this in Rhino 6.
