Could someone explain what im doing wrong or how to address the issue so that I dont run into it when creating another script! thank you.
also explain how to create a brick texture, I have lunchbox plugin if that helps! Thank you so much
Nautilus Shell V1.gh (16.2 KB)
I think explained my issue wrong, this right here is the issue, I dont have a problem with the brick, I can do that, but itâs this that is the main issue for me right now.
I am sure itâs just me but I didnât really understand what youâre after.
I open your file, the loft seems fine. The OffsetS component is causing an issue because your curve is on the ground, not the surface so I turned it off.
Whatâs the problem?
Oh I was messing with the base of the loft to create a foundation. but I fixed it, so youâre saying all the singularity looking mess is because the loft is on the ground?
The dispatch curve is the extrusion I made at the bottom of the loft, I know I couldâve done it in grasshopper but I just did it manually. anyways I think i fixed it by adding a singular curve where that hole was. my problem was the small hole itself not being lofted into point 13
No - I was saying that it seems no âsingularityâ showed up on this side when I opened your file. Furthermore, I mentioned the âoffset curve on surfaceâ component (in grasshopper) was in an error state because the curve to offset lies on the ground as opposed to on the surface itself.
