Trying Boolean Union SDK C++
Hi everyone,
I’m encountering an issue with RhinoBooleanUnion. I pass a valid list of Breps (checked for nulls), but I often get an Access Violation Exception (0xC0000005) inside tl.dll.
The inputs are generated via Offset and might be open Breps or have coincident faces. Here is the helper function I wrote:
ON_SimpleArray<ON_Brep\*> GetBooleanUnion(const ON_Brep\* brepA, const ON_Brep\* brepB)
// 1. Get the active document and tolerance
CRhinoDoc\* doc = RhinoApp().ActiveDoc();
if (!doc) return ON_SimpleArray<ON_Brep\*>(); // Safety check
double tolerance = doc->AbsoluteTolerance();
// 2. Output array to store the result
ON_SimpleArray<ON_Brep*> outputBreps;
// 3. Validation: Ensure inputs are not null
if (!brepA || !brepB)
    RhinoApp().Print(L"Error: Invalid input Breps (NULL pointer).\n");
    return outputBreps;
// 4. Prepare the Input List
// RhinoBooleanUnion requires a list (array) even if we only have 2 objects.
ON_SimpleArray<const ON_Brep*> inputBreps;
inputBreps.Append(brepA);
inputBreps.Append(brepB);
// 5. Execute Boolean Union
// bManifoldOnly = false (Set to false to avoid failures on open surfaces)
bool result = RhinoBooleanUnion(
    inputBreps,
    tolerance,
    false, // bManifoldOnly
    outputBreps
// 6. Check for success
if (result && outputBreps.Count() > 0)
    // Success: The 'outputBreps' array now contains the united geometry.
    // Note: The caller is responsible for managing the memory of the new Breps
    // (e.g., adding them to the doc or deleting them).
    return outputBreps;
// Failure: Return empty array
RhinoApp().Print(L"Boolean Union failed.\n");
return outputBreps;
Does anyone know why this crashes instead of just returning false? Should I be using RhinoCreateSolid or Join for open surfaces? Thanks!
Hi @Mauricio3,
Without a way to run the code here, I cannot tell you why the exception is being thrown.
However, in general you should be passing solid, outward-facing Breps to RhinoBooleanUnion.
Given your image, I have no idea what output you are trying to achieve.
– Dale
