Hi guys, I tried to make a loop to perform boolean union operation. The code is the following:
Two lists of brep are inputs. Search intersection first and then stored the intersected brep into a list for later union operation. The branch list will be updated after that. The code gave me this error: Solution exception: Error in IEnumeratorOfTWrapper.Current. Could not cast: Rhino.Geometry.Brep in Rhino.Geometry.Brep
I was wondering what this means, the union operation worked fine when I unified only two objects here. Thank you for your help.
