fujihira
(Fujihira)
May 28, 2020, 11:58am
1
Hello there,
Rhinocommon CreateBooleanUnion doesn’t work well.
I think it’s probably due to tolerance, but after trying several tolerances, the booleans on this model don’t work.
Rhinocommand’s BooleanUnion worked with this model
Does anyone have any idea what caused this?
Thanks a lot
BooleanUnion.3dm (187.0 KB) BooleanUnion.py (516 Bytes)
One of your Breps is
non-manifold , So you’d better use
another overload of Brep.CreateBooleanUnion that accept an option for non-manifold Breps:
import Rhino.Geometry as rg
from scriptcontext import doc
objs = rs.GetObjects("select objects")
breps = [rs.coercebrep(obj) for obj in objs]
def BooleanUnion(uBreps):
tolerance = sc.doc.ModelAbsoluteTolerance
newbreps = rg.Brep.CreateBooleanUnion(uBreps, tolerance, False)
if newbreps is None or len(newbreps) != 1:
print('ERROR')
return sc.errorhandler()
return newbreps[0]
brep = BooleanUnion(breps)
doc.Objects.AddBrep(brep)
BooleanUnion.py (505 Bytes)
fujihira
(Fujihira)
May 28, 2020, 12:42pm
3
Hi, @Mahdiyar Thank you for the reply.
Its works!!
Thank you so much!!
