Troubleshooting RHI Installers
I was trying to install the clipper plug-in, latest version (Windows Installation (0.3.0, Rhi)) from:
Droppped the .rhi file into rhino and this error (screenshot) popped up.
Following instructions on this page I copy the summary below and attached the latest log.
----- Summary -----
Unable to fix RhiExec on your computer. Please send this log to support@mcneel.com for help.
RhiFix.exe version 6.0.6726.16913 starting…
------Details------
  • Detecting Rhino Installer Engine Executable … not found.
  • Detecting Rhino.InstallerPackage registry key in HKLM … not found.
  • Detecting .rhi registry key in HKLM … not found.
  • Detecting Computed .rhi File Association … not found.
  • Detecting User .rhi File Association (Windows 7) … not found.
  • Detecting User .rhi File Association (Windows 10) … not found.
  • Detecting 32-bit Rhino 5 … not found.
  • Detecting 64-bit Rhino 5 … not found.
  • Detecting Rhino 6 … 6.23.20055.13111
  • Detecting Rhino 7 … not found.
  • Detecting File association mismatch … found.
  • Fixing Rhino.InstallerPackage registry key in HKLM … failed.
  • Fixing .rhi registry key in HKLM … succeeded.
  • Fixing File association mismatch … failed.
----- Data -----
  • rhi_system_extension_registry_key_found = False
  • rhi_file_association_exists = False
  • rhi_file_association = C:\Windows\system32\OpenWith.exe
  • v6_install_path = C:\Program Files\Rhino 6\
  • v6_version = 6.23.20055.13111
  • newest_rhino_version = 6.23.20055.13111
  • v6_install_path_exists = True
By my own means I associated the RHI file to Rhino, dropped it into the Rhino Canvas, and Rhino entered an endless loop of opening new Rhino windows that forced me to shut down my pc.
Thanks for any help,
Shynn
Rhino can’t handle *.rhi files.You can manually associate *.rhi files to Rhino Installer Engine, in the following location:
C:\Program Files\McNeel\Rhino Installer Engine\x64\rhiexec.exe
This method works for *.rhp files not *.rhi files.
