Trouble with Trim Solid
I’m having a bit of trouble with ‘trim solid’ in grasshopper. I have placed spheres at the joints of all the joints on the edge of a surface, but when I use trim solid, it fails randomly for a few spheres in various places (not pattern that I can detect):
I’ve confirmed that there is a sphere located there:
The script is not throwing any errors:
(and I’m reasonably certain that the trees are matching up for trimming because the other joints work, plus a few tests including flattened trimmers)
I’d be happy to share a file, but this one is a monster. Any thoughts why this might be failing? What obvious thing am I missing?
Thank you!
You could extract (internalize) just the significant portion of the geometry and post it.
Without file I would guess data mismatching. When you bake it and it works in rhino you can exclude a tolerance issue.
Hello Baris, thanks for the pointer, please see the attached internalized file. Are you able to run it? (warning, longish computation time) BGC_internalizedCutter.gh (913.2 KB)
I did a bake test and it was able to split the surface fine in rhino directly so it doesn’t seem to be a tolerance issue? I hope it isn’t a data tree mismatch, in the disabled component I flattened the cutters to completely sidestep this issue (but that takes even longer to run).
Thoughts?
seems to work over here, in which branch do you have the problem? Maybe I ve overseen it.
Datastructure seem to be ok
I’ve pulled out one of the offending surfaces (branch {8}) as well as the sphere. I bumped up the size as well to make it easier to see. Please see the attached file.BGC_internalizedCutter_highlights.gh (916.6 KB)
I’m also getting some really surreal behavior in rhino now too. If I bake the spheres and surface, a split operation doesn’t work. But if I rotate the sphere in place, the split function starts working. What am I missing? File attached with a split fail and split success.BGC_Splitfail.3dm (1.4 MB)
Hi, ,I am not at a pc right now.the second behaviour you describe could be the seam of the sphere. Later I’ll check your file
That was it! Thanks so much. I added some random rotation to all the spheres and it worked great in both grasshopper and rhino.
Is the seam problem expected behavior? or should it trim across the seam?
Instead of random rotating you could construct them the way the seam is always away the surface.just to be sure it works.
