I am developing a Grasshopper plugin and working to ensure its compatibility with Rhino 8. I create a mesh and add texture coordinates for each vertex in the mesh. I then create a DisplayMaterial, then using SetBitmapTexture to set the texture from a bitmap file. Then I am trying to use DisplayPipeline.DrawMeshShaded with the mesh and the display material to draw the mesh. The result is that the textured mesh has a single uniform color. If I change the bitmap file that the texture is set from, then the displayed color changes. I expect the mesh to have different colors, based on the texture coordinates. Additionally, if I bake the mesh with texture coordinates, then it is displayed correctly in a rendered viewport when a texture bitmap is specified.
The procedure described above worked without any problems in Grasshopper in Rhino 7. Any suggestions what the problem is? Is this an issue in the beta or how I am using it?
Attached is a minimal code example that duplicates the problem. Model and texture images are included in the archive.
~Michael GHTextureTest.zip (143.2 KB)
