I’ve googled and can’t for the life of me get the text from a leader to be closer to the leader itself. I’ve tried pulling on the control points, alignment and turning on and off the “landing”, but nothing seems to help… I’m trying to remove the space contained by the red rectangle in the attached image…
If you start a new file from a factory-default template and use the Default annotation style, there shouldn’t be any space there. In the attached image, I have only changed the curve type to spline as in your image:
Thank you! That was the tip I needed - I imported the default style and was able to compare it to my own annotation styles to figure out the discrepancy. Cheers.
