jmarsh
(Jmarsh)
April 6, 2023, 2:35pm
1
I added walls and curtain walls to a Wall component from RiR to bake some reference geometry into Rhino. The traditional walls baked, but the curtain walls did not. I also tried to get element geometry and bake that into Rhino.
Japhy
(Japhy)
April 6, 2023, 3:06pm
2
Hi Jmarsh,
A Curtain Wall is container element, which inherently doesn’t hold any graphical geometry but is the parent of Panels / Mullions contained within.
Hi Trumori,
There’s a couple ways to get the curtain wall panel geometry.
Typically you want a particular Wall or Wall Type before getting the panels, which you can do by the Analyze Curtain Wall. This allows you to get Grid info as subsequent Panels. Here you could change the Type if need be.
[image]
Here are a couple less precise ways to get the Panels
[image]
https://www.rhino3d.com/inside/revit/beta/guides/revit-curtainwalls
jmarsh
(Jmarsh)
April 6, 2023, 4:32pm
3
Thanks! Learned something new about the Revit API.
