Hi there,
I’m struggling to figure out why using the split command worked on one area of my surface, but failed to work on another. Is there something I am missing? is it a bug? or do I need to change something in my settings?
Thanks in advance
Hi there,
Thanks in advance
@milosutter, hard to say from an image, my guess is that curve was not closed before you extruded into your cutter polysurface. Run _SelClosedCrv
to find out if the curve is closed. If it is not selected, use _CloseCrv
, then trim or split.
c.
Thanks for the reply. It is closed; I’m still perplexed as to why I can’t split!
Can you post your file containing the problematic objects ?
c.
Right. Thanks -
150804_Brunette_split surface struggle1.3dm (515.3 KB)
edit: also need to change transparency of the surface
( Changing transparency on a hatch )
Select your cutter object, then run _ShowEdges
. The cutter is not closed. Close it along the two vertical naked edges, eg. by lofting a surface between them, join it with the cutter and split will work.
c.
Thank-you so much! that was the exact problem.
-M
