Hi there, am having some issues with Trim Region component. The curves wont trim properly. Have tried to pull the curves to the surface before trimming but am still unsure why its not trimming properly, will really appreciate the help.
Hi @HS_Kim, thanks so much for the help, really appreciate it ! Have tried to manipulate around the slider for the offset curve on surface, and am not sure if its my surface issue, but it seems to work only when its offset in a certain range. After it passes a certain value, it doesnt seem to shatter the curve properly. Even with my previous script this seems to be an issue. Would really appreciate if could help. Here are some photos illustrating what I meant. Sometimes the components turn Red as well, but somehow the data manages to pass through.
