I have encountered a case where the trim with curve does not function as expected. As per the discussions below, I have the plane added. Doesn’t help. In this case the curves coincide with the boundary in some cases and I would understand the struggle there, bu there are parts that are clearly outside and are not given out as such. Anyone knows what is happening here?
Simple trim with regions problem - #2 by HS_Kim
Trim region fails with lines - #3 by antoinemaes
Trim with region error.gh (26.3 KB)
