I’m using Revit 22 and Rhino Insadi.
I limited the model to Section Box, and it contains a point cloud. Is there a way to use Section Box to extract only the points visible in Section Box to Grass?
And I have a second problem: I’m linking the point cloud from this file, but it appears incomplete in Rhino and Grass and looks different than in Revit.
There are bounding box filters that will get only visible. I can test the workflow and provide an example when I have access to Revit (probably tomorrow)
How big is the revit point cloud (number of points)?
The main problem is that the points loaded into Revit and the ones I export to Grasshopper through this node don’t match visually. It feels like not all the points are imported.
