Trim not working as expected
Hello, I am using Rhino to generate unrolled shapes that I can then laser cut to produce physical models out of chipboard.
I am trying to use Trim to cut out the intersecting curve (created by the cylinder) from the truncated cone, but when I select the cylinder as the cutting object, and the cone as the object to be cut, I am left with just the overlapping piece and cylinder, while the cone disappears. I have also used Intersect to isolate just the curve where the two overlap, and then attempted to trim using that curve, but this also does not result in a cone with the curve cut out of it. I have successfully done this in the past as shown the attached image, but have not been able to replicate it.
My file is also attached for reference.
can-2.3dm (2.5 MB)
Hey Brenda, the tube is an extrusion.. explode it back to a surface and try your trim again..
it’s working here when I do that.
Thanks Kyle, that worked!
sweet-
fwiw, you may want to toggle extrusions off unless you need them for some specific reason-
useextrusions = polysurface
happy modeling!
