Cannot trim parts of surface. Why?
I’ve managed to trim away most of the centre surface overlaps on these cups but there’s two parts remaining.
They must overlap because I’ve trimmed one side of the cut line…
Any help would be most appreciated…
Tetrapod cutting 2.3dm (187.0 KB)
Hello - try this:
Start Trim and use Ctrl-Shift click (Sub-object select) to select just the edges of the cont to trim with as the cutting object.
As your shape is symmetrical, why don’t mirroring the other side ?
Hi Pascal,
Thanks for the suggestion - unfortunately it doesn’t work for me.
It’s just like Rhino doesn’t think the overlaps are there for the trim command, or thinks they don’t overlap…
I even tried deleting a cone end cap and selecting from there.
This was developed in Grasshopper.
Hello - see if this helps at all
Hi again Pascal.
Your first suggestion worked!
I missed the sequence first time.
Thanks again for your help.
