Hi V5.
I need to trim off the bit of green surface appearing within my trim cylinder.
I have exploded the green incase that helped though there was nothing to explode,
I have tried selecting the green long portion to see if cylinder needed flipping, it didnt trim so cant be that.
Why is such a simple task failing ?
cylinder was a circle extrude curve make surface.
green started life as a pipe.
Hi.
The seam thing, blimey not had that for years.
trouble is the extra lines add to the clutter and confusion, bad enough as it is on what I am doing.
I would be trying to hide things when they belong to what I am working on.
This could explain a few other trim fails, where intersect solved it . Using tube and pipe and sometimes trim failed.
This will also work if you shrink the green surface before trimming it or Intersect first and trim with the curve. This seems slightly buggy to me.
Fixed in V7/WIP.
