Hi there,
The trim command is super important, and very intuitive to use. However, I can only reliably use the drag window over items to trim. If I use -selbrush to make quicker and more accurate selections, it works sometimes, but often causes a fatal freeze, which on about 5 occasions has lost me 40mins of work.
I just did this test, and it froze.
Using the trim command, I selected the internal rectangle as the cutting object, then did '_SelBrush and selected the internal lines which worked (1, 2). When doing the same thing but brushing the curves outside the rectangle, it freezes indefinitely(3).
2.
3
Is this something which can be fixed?
I’ve attached the file for testing if you want.
test.3dm (470.8 KB)
Best,
Jeremy
