So, I’m trying to trim a bunch of lines within a narrow area at an angle and I wish I could just draw a line through all the lines I’d like to trim rather than have to select each line or use the selection rectangle. Being set an an angle makes the rectangle selection method not much more efficient than selecting the individual lines. Is there a way to change the selection method from drawing a rectangle over or through the lines I’d like to trim to drawing a line through the lines I’d like to trim? Or is there a way to trim all lines within a specified region?
I asked this elsewhere and someone suggested CurveBoolean, which I don’t think is what I’m after. I’m not trying to create a new line (or curve/shape) I just want to be able to quickly draw a selection line through the lines I want to trim. Example below.
