Is there anyway to trim a hole in an existing hatch pattern without having to recreate it?
Thanks
Thanks
No, but you can turn on controlpoints and edit a hatch.
I wish for a full edit too, kind of like how we edit a block would be nice.
Fastest way to edit now is to duplicate the boundry of the hatch, edit and/or add curves to that, then rehatch, and match to the old hatch, and delete the old.
Thanks. The dupBorder trick works nice.
Yes more hatch edit features would be nice.
Dennis
Also on my wishlist!
Hey djnelson75
I have been working a lot with hatches lately, and missed this function a lot, so I decided to give it a try and wrote this script that automates basicly what Holo wrote.
Let me know what you think: is it helpful? noticed any bugs? is it user friendly? is it something you would do differently? Thx for your input!
Paste text below into a new button of your liking:
! _-RunPythonScript (
#HatchEdit
#This script updates an existing hatch to fill a new region defined by a selection of boundary curves or blocks containing curves
#Krausz Zsolt 20200418
import Rhino
import System.Guid
import sys
import scriptcontext as sc
import rhinoscript.utility as rhutil
string1 = "Select boundary curves or blocks"
string2 = "Select hatch to edit"
def DuplicateHatchBorder(hatch_id, outer=True):
"""Create curves that duplicate a hatch inner, outer or both borders
Parameters:
hatch_id (guid): identifier of a hatch
outer (boolean, optional): the border curves to return
True=exterior
False=interior
Returns:
list(guid, ...): list of curve ids on success
None: on error
hatch = rhutil.coercegeometry(hatch_id, True)
curves = Rhino.Geometry.Hatch.Get3dCurves(hatch, outer)
if curves is None: return sc.errorhandler()
tolerance = sc.doc.ModelAbsoluteTolerance * 2.1
curves = Rhino.Geometry.Curve.JoinCurves(curves, tolerance)
rc = [sc.doc.Objects.AddCurve(c) for c in curves]
sc.doc.Views.Redraw()
return rc
class Hatch:
def __init__(self, id):
self.id = id
self.StoreAttributes()
rs.LockObject(self.id)
def StoreAttributes(self):
# store attributes of input hatch
self.pattern = rs.HatchPattern(self.id)
self.rotation = rs.HatchRotation(self.id)
self.scale = rs.HatchScale(self.id)
#store inner and outer boundaries of input hatch
self.innerBorder = DuplicateHatchBorder(self.id, False)
self.outerBorder = DuplicateHatchBorder(self.id, True)
def GetNewBoundary(self, crvs):
rs.UnselectAllObjects()
rs.SelectObjects(crvs + self.outerBorder + self.innerBorder )
if rs.Command("_-CurveBoolean", echo=True):
self.newBorder = rs.LastCreatedObjects(select=False) #replace new border with the selected region
else: self.newBorder = self.outerBorder + self.innerBorder # in case no region is selected maintain old border
def RefreshHatch(self):
sn = sc.doc.BeginUndoRecord("HatchEdit")
newHatch = rs.AddHatch(self.newBorder, self.pattern, self.scale, self.rotation) # create a hatch with new boundary, same pattern attributes
rs.MatchObjectAttributes(newHatch, source_id=self.id) # match new hatch attributes with old one
rs.UnlockObjects([self.id, newHatch])
rs.DeleteObject(self.id) # delete original hatch
if (sn > 0):
sc.doc.EndUndoRecord(sn)
def DeleteTemporaryGeometry(self):
rs.DeleteObject(self.outerBorder)
rs.DeleteObjects([crv for crv in self.newBorder])
rs.DeleteObjects([crv for crv in self.innerBorder])
# ask user to select the hatch to edit
id = rs.GetObject(message=string2, filter=65536, preselect=True, select=True)
#test if selection is not empty
if id:
hatchObj = Hatch(id)
cutBoundaries = rs.GetObjects(message=string1, filter=4|4096, preselect=False, select=True)
if cutBoundaries:
hatchObj.GetNewBoundary(cutBoundaries)
hatchObj.RefreshHatch()
hatchObj.DeleteTemporaryGeometry()
else:
rs.UnlockObject(hatchObj.id)
del hatchObj
rs.Redraw()
Fixed some bugs, find the updated script below:
Zsolt
#HatchBoolean
#Krausz Zsolt 2020042
#Error log
#maintains original layer for all pieces
#hatch base implemented
import Rhino
import System.Guid
import sys
def HatchBasePoint(hatch_ids, base_point=None):
#sets or returns a hatch basepoint
# test if user specified one id only
if type(hatch_ids) is System.Guid:
hatch_ids = [hatch_ids]
# initialise return values
r_count = 0
r_list = []
# go through the list
for hatch_id in hatch_ids:
rh_hatch_obj = sc.doc.Objects.Find(hatch_id)
if base_point == None:
# if no point was specified, return existing basepoint of the hatch
base_point = rh_hatch_obj.Geometry.BasePoint
base_point = rs.coerce3dpoint(base_point)
r_list.append(base_point)
else:
# if a point was specified, set it as the new basepoint of the hatch, and increase count
rh_hatch_obj.Geometry.BasePoint = rhutil.coerce3dpoint(base_point)
rh_hatch_obj.CommitChanges()
r_count = +1
#return the ids of the basepoints or the number of hatches modified
if r_count == 0 and len(r_list)>1:
return r_list
elif r_count == 0 and len(r_list) == 1:
return r_list[0]
else:
return r_count
Parameters:
True=exterior
False=interior
Returns:
None: on error
return rc
class Hatch:
self.id = id
# store hatch base point
self.base_point = HatchBasePoint(self.id)
# create a hatch with new boundary, same pattern, scale and rotation
newHatch = rs.AddHatches(self.newBorder, self.pattern, self.scale, self.rotation)
HatchBasePoint(newHatch, self.base_point)
r = rs.MatchObjectAttributes(newHatch, source_id=self.id) # match new hatch attributes with old one
rs.UnlockObjects([self.id]+newHatch)
if (sn > 0):
if id:
if cutBoundaries:
else:
del hatchObj
rs.Redraw()
hey
any idea how to insert this script into rhino?
Hello - note Trim
works on hatches in V7.
The post above has the complete macro for running the script, though, so far it is not working here.
