Hello everyone, how can I create the pattern I shared below? I’m using a triangular grid, but the angles of the triangles are not the same as in the photo.
I wouldn’t think at that like triangles but as squares with diagonals splitting them into 2 triangles
sometimes the diagonal is between vertexes 0,2, sometimes between vertexes 1,3
alternatively, you could rotate some squares and spli all them by the same diagonal?
…or set of duplicated squares where vertex X or X+2 is removed.
