i built a truss with grasshopper which goes along a surface.
instead of a normal truss i want to make a triangle truss (
Can someone help me?
There are a ton of examples online for creating this sort of geometry in grasshopper. Here is one by David Rutten: Triangular Truss - Grasshopper
In general, you are going to want to divide your curves into lists of points and use shift list or relative item to create the struts.
thank you, i’ll try!
Duplicate topic, someone merge maybe?
Triangle Truss from normal truss, grasshopper - Grasshopper - McNeel Forum
