TREE STRUCTURE COLUMNS - Anemone
Hi all!
I am trying to create continuous tree structure columns using Anemone. But because the input is a point and so has to be the output, I can’t get a set of columns, but only their base points on each floor and only one column at a time. Does anyone have any idea how this problem can be solved?
Please, find a sketch of my idea and the grasshopper file attached.
Thanks in advance!
Tree structure - anemone.gh (16.0 KB)
You could possibly do this with a linear array instead of a loop in anemone cause what you are doing seems to be nothing more than an array …
Tree structure - array.gh (32.8 KB)
Thank you a lot!
I tried to think of an example where a loop makes sense.
In this definition, a series of three points is moved vertically with a random distance and then each point gets projected to the next surface in two random directions. In this case you need a loop, since you have twice as many points after every loop. The resulting lines can be cleaned up with the topologizer plugin.
Tree structure - array and anemone.gh (41.3 KB)
This one worked for me. I couldn’t use the array because the following trees have to choose where to start - from the first branch point or the second. Thanks a lot!
