Hello. I have a Question/Issue regarding Anemone and the loop function. Basically I want to do a loop inside a loop. In the picture we have two lines (A and B) divided into 100 sections. I also have two square surfaces, both located at the beginning of both lines. What I want to do is use the loop to move the surface down the lines point by point. Imagine if I just have line A. To solve the task I take the length of my point list -1 and use this as number of repeats. Input for D0 is -1 and inside the loop I use an Addition +1. I put the solution in the index of a list item from the point list and move the surface to that point and also put the solution of the addition in the loop end. If I start the loop now, my surface walks down the line until the end. Easy as that.
I am struggling with the second time. For every step I walk down on Line A, I want the surface on Line B walk the whole line to the end and back again. I tried a lot to use the fast loop inside the loop somehow to figure it out, but I didn’t found any solution. Is there anyone who could help or have an idea. Thank you so much. If you need any further information please tell me!
