I’ve noticed recently that when printing to PDF, if a surface has a transparency map (to make a net), instead of being transparent like it shows in the rendered view port, it fills in with white.
Rendered Viewport the transparency map works fine:
Print to PDF using Rhino PDF and CutePDF the transparency is white instead. (shadows still work)
Is there a setting I’ve clicked by mistake or something that changed with a recent update?
