I’m trying to create a smooth fillet from my vertical face to a flat and angled surface at the same time. The vertical face has 2 degrees of draft. This is part of a fiberglass part so all corners need to have a smooth transition to them.
I’m attempting to to add a .1875" (3/16) fillet to each of these edges. with the Filletedge command it results in this.
@Alex_Miller1 Any reason you are using Rhino 7.7 and not the latest SR(37)?
I’m getting this in Rhino 7.37 which is not exactly correct, but can be repaired quickly with ReplaceEdge:
No reason at all. its a work computer and has been neglected for a while. I never even realized it was out of date. i will update that now. It defiantly looks better. But feel like it could be smoother.
