Tooltips not showing
Often the tooltips are not showing up in Rhino 8, which makes the toolbars quite useless, particularly for new users.
Known issue, usually minimizing and then remaximizing Rhino - or switching applications and back again - fixes it (at least temporarily).
Sometimes switching applications and reopening Rhino still does not help.
This new toolbar system in Rhino 8 is a very questionable ā€˜improvement’ which made things worse. It should be fixed ASAP!
I don’t see the tooltips as being directly related to the toolbars as they are also elsewhere, such as in the layers panel, but yes, there are elements of the V8 UI that definitely do need fixing.
But why are not osnap, and some of the icons in the right containers affected, for example in the properties, materials, textures and environments panels and also ā€œnamed CPlanesā€.
Many regards Per Malare
