Toolbar is not loaded when my plugin is loaded
I have created a plugin and I packaged it in a yak file.
The folder of my plugin contains these files:
When I install my yak file in my Rhino installation my plugin is installed correctly.
In fact, I can see the files of my plugin in Rhinoceros folder:
C:\Users\jaume\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\RhinoTdynWindTunnel\1.0.0
However, my toolbar, that is defined in .rui file that is saved with rhp file and they are named equally, is not loaded. Nevertheless, I can load my toolbar manually.
I would like to load my toolbar automatically when my plugin is installed and rhinoceros is opened
Hi @Jaume_Sagues,
Please go to this folder:
%APPDATA%\McNeel\Rhinoceros\<version>\UI\Plug-ins\
Once there you have to delete your specific RUI file (please delete the bak files as well).
You’ll find all the information about this on this link:
Regards,
Pedro
I installed the last version of Rhino7 and this problem has been solved.
