How to export .rui file with a plugin?
I have made a Toolbar in Rhino, which acts as a graphical way to run my command. I put the .rui file of it in the .rhi plugin installer. The plugin installs successfully, but the Toolbar shows up as empty. What should I do to make sure that all the toolbar buttons, icons and details are properly installed, along with the plugin?
Hi @alexian007,
Does this help?
– Dale
Yes @dale, I had gone through it before briefly, but I once again read it in a detailed manner.
I was not clearing the previously staged toolbar files from Rhino, so this is why the issue was occuring.
Thank you, Dale :slight_smile:
