Task:
I want to create a toolbar with 2 buttons.
Button 1 should do “! A” for left click, “! B” for right click.
Button 2 should execute “! C” for left click.
The button images are SVG files.
At the end I need a file to give to other users.
I assume this can be a rui file, I’m not sure anymore.
The ‘install’ procedure should be simple, at best drag&drop into Rhino.
I have made several attempts now.
And have read ‘everything’ in the help about containers, macros, libraries, toolbars, buttons, panels, etc.
I can’t get a file that is independent of some unknown other settings or the like.
Now I could describe in detail what I did (obviously not correct).
Would’nt make much sense.
How about the other way around?
The creator(s) of the new system in V8 could give a step-by-step instructions on how to get a deployable toolbar.
Should be easy for the creator!
I now altered the example toolbar to my needs, a have set the pictures and commands.
In the Macro Editor I doublechecked that it is ok what I have done.
And saved the container as a rhc file.
Initial tests were good, on drag&drop I had the wanted toolbar in a container, even after _Reset.
Now I tried again and all my work is gone.
No idea what happened!
I inspected my rhc file with XML Notepad.
The macros I made are still there, but this is not seen in the toolbar.
Also I see the node ‘referenced_rui_files’.
Aha, means the rhc is not enough, I need the rui as well.
The source node tells me this is the referenced rui file: C:\Users\Charles\AppData\Roaming\McNeel\Rhinoceros\8.0\settings\Scheme__Default\imported_rui_files\charles_d59de99e-f30e-4065-a768-d299275af3e5_d59de99e-f30e-4065-a768-d299275af3e5_d59de99e-f30e-4065-a768-d299275af3e5_d59de99e-f30e-4065-a768-d299275af3e5_d59de99e-f30e-4065-a768-d299275af3e5.rui
When I check the Toolbars dialog, I have interesting libraries.
@Charles it would be helpful if you give clear steps how to reproduce.
For me it was the first time I tried this container export and found it attaches an id to the name. In your example, it looks to me the id is attached twice.
Can you send me the rhc file that fails?
