Hi, I have two data trees and I would like to use the SCX component to make a comparison between a data tree of surfaces and a data tree of curves. I can perform the correct calculation by grafting input surfaces and flattening input curves however this makes 1.6m comparisons whereas a branch to branch comparison should lead to ~550k comparisons. Any suggestions on doing this neatly? I’d like to avoid exploding trees and creating multiple SCX components
New toolset unlocked! I will need spend some time figuring how this anemone loop works exactly however this is indeed the level of automation that I was looking for. Thank you sir
