Problem with data matching
Hey!
Since a couple of days I am struggling with a grasshopper definition. I think it all comes down to data matching.
As you can see in the picture of the GH canvas I have six branches of lines consisting in only one line per each. In the picture of the viewport it is visible that only 4 lines actually exist.
What is happening here!? I´m pulling my hair over here! This doesn´t look normal at all.
13.gh (41.2 KB)
2 lines are duplicated / identical.
bake them
_selLast to select backed geometry. → 6 Curves
_selDup (see screenshot above )
Great.
Still, what could I do to get the same for the other chunk?
changed to GH category
minimunbb_14_tp.gh (56.0 KB)
the above definition uses the first planar face per brep.
(assuming there is one, and assuming that the uv-direction of the underlaying surfaces fits)
you might want to do some sorting here, to decide, which surface / plane to use.
using a plane to generate a boudingbox per object in the spacial direction of above plane
evalute the bounding box to get the points / create the lines.
does this help ?
EDIT:
(added screenshot)
Above approach does not answer the initial question how to sort / access / match the given Datatree.
Instead of fiddling with datatrees i prefer to have the geometry already generated in a readable order.
A boundingbox / evaluate Boundingbox will have a consistent order of faces.
Regarding readability, i do not mind to have a few components 3 times - for more complex definitions this might be a cluster.
I think it s a good practice to check the data-structure after each step / component and keep it simple but in a meaningful organisation.
This List Item can’t be working properly, there is a 1-level tree in the first input and a 2-level tree in the second input.
I used Graft Parallel from Elefront plugin to duplicate the branches.
Then you can avoid your Partition List with a simple Polyline.
13.gh (28.1 KB)
Hi @magicteddy. Your help was lifesaving. I managed to solve the issue by using the component you suggested.
You also pointed at the problem with the data matching. I had the feeling that that might be the cause. This is the very thing that I keep struggling to understand with grasshopper. Could you please suggest a source where I could learn about the topic?
Of course it helped! Thanks @Tom_P for taking the time to review my definition and provide guidance!
May I also ask: how could I achieve the same by using just grasshopper native components?
Data tree management is indeed a bit tricky but there are a few rules to keep in mind :
  • provide lists that have the same length, or trees with the same structure (i.e. same amount of branches, same branches numbers, and same amount of items per branch).
  • if you provide lists of different lenghts or trees that don’t match structure, the last item/branch only in repeated to match the longest list/tree, so in 99.9999% of cases this results in errors.
  • if you provide different structures (for instance an item and a list, or a list and a tree) to a component that has several as item inputs - and that is the vast majority -, then Grasshopper will repeat the weakest structure as many times as necessary to match the strongest structure : it will therefore create repetitions.
A great video there (although for the last minutes, I’m a bruteforce Simplify/Trim Tree guy instead of Shift Paths :D)
It’s a great exercice of Duplicate Data and Partition List that you’ll probably want to do once to understand the principle, then switch to Graft Parallel for the rest of your life !
13_NativeGraftParellel.gh (43.2 KB)
Edit : another native solution with Unflatten Tree that works in this case.
13_Unflatten.gh (30.5 KB)
My solution uses only native gh components.
See my edit in my initial post with a comment on data-structure.
Hi @magicteddy and @Tom_P. You make so happy by providing such rich answers and valuable content. I can not check them all right now as you got me in the middle of a project, but they look really good and promising. I´ll get back to you in the future for sure.
