Some questions about shift paths component
Hi all,
I’m learning grasshopper recently, I pick up some finished grasshopper documents to analyze
I got stuck in understanding this shift paths component in this case
How does this component work in this case?
here is the GH file:
shift paths.gh (43.3 KB)
You have 6 curves so, SCX returns 6 additional subbranches per each surface(162 faces * 6 curves = 972 branches).
So, the data tree structure after SCX is different from it’s upstream.
“Shift Paths” with offset -1 let you recover the data tree structure which is the same as the upstream’s “Graft”.
thanks a lot, very clear explanation
