Toggle Sun Panel not working
Hello! I have downloaded the latest version of Rhino 7 a couple of weeks ago. I use V-ray for rhino to do renders on a daily basis and make use of the “Sun” command very often. The last couple of days this command has stoped working. I can’t seem to understand the reason, but the Sun editor panel just does not appear.
I would like to know if anyone has the same problem or if know how to solve it.
Thank you.
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
Hey! This is the info!
Thanks
Rhino 7 SR10 2021-9-13 (Rhino 7, 7.10.21256.17001, Git hash:master @ 68677dc86520a0de9485d8b8fa2e841e757733f3)
License type: Educational, build 2021-09-13
License details: Stand-Alone
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-28-2018 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 (NVidia) Memory: 4GB, Driver date: 6-9-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.80
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-9-2021
Driver Version: 27.21.14.6280
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\darig\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2020.3.3.0\6\Fologram.IO.Rhino3d.Win6.rhp “Fologram for Rhino” 2020.3.3.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.10.21256.17001
Hi -
Thanks for that information.
In the PluginManager, please make sure that the Renderer Development Kit is both Loaded and Enabled. Restart Rhino if it wasn’t.
If it was loaded and enabled, please disable both Fologram and V-Ray and check if that makes the problem go away.
Thank you so much. The problem has been solved. I believe the problem is the Fologram Plug-in.
Kind regards,
David
Hi I am having the same problem.
Where is Fologram? I found V-ray and enabled it, but I can’t find Fologram.
Thank you
Hi Gazelle -
That would be the expected behavior if you didn’t download and install that plug-in.
Please run the Rhino SystemInfo command and copy-paste the output here.
Hi Wim, I am having a similar issue. My sun command seems active, but I can’t toggle the control panel when I type in the command. My pluginManager shows the Renderer Development Kit as active. What should I do?
Hi Francisco -
Similar issue, similar question:
Thanks,
Here you go:
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Educational, build 2024-04-16
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [34% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 2-22-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4080 Laptop GPU (NVidia) Memory: 12GB, Driver date: 3-21-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.95
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 3-21-2024
Driver Version: 31.0.15.5195
Total Video Memory: 12282 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
Hi Francisco -
Thanks for the system info.
What makes you say that the sun command seems active?
Can you get the panel to show when you use the menu items instead of the command?
@wim
hi, i don’t know since when my render mode looks super weird(shadows and lightnings). i also be using Vray to render and the lightnings are also weird.i don’t know if it is from the same problem? i’ve tried basically everything in the sun option, but didn’t help. Could you help me find out my problem? Or maybe is there a way to set everything back to defult? down below is my system info, thank you
Rhino 8 SR18 2025-4-10 (Rhino 8, 8.18.25100.11001, Git hash:master @ 5d157e876c23ece334d9c8666b8513ffc6d4a98d)
License type: Educational, build 2025-04-10
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4070 Ti (NVidia) Memory: 12GB, Driver date: 4-12-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 576.02
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-12-2025
Driver Version: 32.0.15.7602
C:\Program Files\Rhino 8\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino8.rhp “Karamba3DLicense”
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.18.25100.11001
Hi 吳玄燁 -
Please post the 3dm file so that we can check if there’s anything with that that might explain things.
@wim sure, here it is one of my files, but i think every 3dm files of mine have the same problem
@wim Sorry to bother, but may i ask if you got any idea?
Hi Wim, I am having the similar problem, the sun option was on but no shadow casting.
