Just as the title says, toggling open windows within Rhino does not work with command + ` shortcut. Minor issue but frustrating all the same.
hi @Kaleb_Seigle yes this issue is logged as RH-70582 Rhino WIP: Ctrl + Tab no longer works to switch between viewports
I’m not sure this is the same issue I’m referring to. My problem is not switching between viewports, it’s switching between discrete open windows aka separate files. This doesn’t work reliably with the native Mac window toggle keyboard shortcut. Thanks!
sorry, I got confused, since you were mentioning windows rather than documents.
I just tried this here Cmd+` and Cmd+Shift+` seems to switch between documents, but it seems more finicky than in Rhino 8
Can you confirm that Cmd+` only works until it hits the ‘end of the list’ and then you have to Cmd+Shift+` to browse back?
No problem, Gijs. I can’t get either keyboard combo to do anything.
Just following up here to see if this issue can be addressed. It’s pretty frustrating not having the ability to quickly cycle through open documents. I can occasionally get Cmd+Shift+` to work but it’s very erratic. Cmd+` doesn’t work at all, to the best of my recollection. Thanks!
Hi Gijs,
Sorry to keep nudging but this erratic window toggling continues to be problematic. Working between multiple open files has really become a drag. Any chance this could get some attention? Thanks!
It seems to work here, but not past the end of the list. But it seems that you’re not being able to switch at all, which I can’t reproduce here.
I’ll log the issue I am experiencing anyways, and mention the behavior you’re getting.
RH-98442 Cmd + ` doesn’t work (as in Rhino 8)
Thanks Gijs,
I can switch sometimes but it’s seemingly random though I’m sure there’s some underlying pattern/logic that I haven’t picked up on yet. One thing I have noticed is that it is more reliable on my single monitor MacBook setup. The multi monitor Mac mini setup is far more unreliable when it comes to the window toggling. This is on a list of several other general multi screen annoyances but that’s for another day. Thanks!
Hi Gijs,
Here’s a screen recording with keystrokes shown on screen. Hopefully this helps to give a better sense of this window toggling issue. Also attached are the demo files from the video although this behavior is present with any and all files. Thanks!
sysinfo.txt (7.1 KB)
File3.3dm (40.2 KB)
File2.3dm (40.2 KB)
File1.3dm (39.6 KB)
