So these are X, Y, and Z values in the list and there are 5 points might be more which is extracted from excel, I need to combine coordinates (X, Y, Z) with one output which would look like in a single list (20,20,0), (22,20,0), (24,20,0), (30,30,0), (10,25,0) and more depending on the inputs and then convert into coordinates.
I have created one file but I need to eliminate the process of adding the coordinates manually in the list item and can be converted directly based on number of points.
Can someone please help me with this?
Thank you!
