…is there any way to increase the size of the active window grip (?) ie the bit you grab to re-size the viewports…
Hard to hit the spot with wacom pen…
Hi Cairn - not that I know of. But it is not the cursor itself that needs to get bigger here, right, it is the target area where the cursor shows up - do I have that right?
There is a test command named “TestFrameStyle” which cycles through 3 different frame sizes. This will make the area larger for grabbing with the cursor.
Exactly.
This helps a bit, Thanks! @stevebaer
