I cannot seem to change the column size to get all of theses items closer together? Can anyone point me in the right direction?
if you hover the cursor over the left side of the inspector panel you’ll get a cursor that looks like :
…when you have that cursor, click and drag to resize the panel… there is a limit to how far right / skinny you can make it.
(or, i might be misunderstanding ?)
Hi Jeff,
Thanks for responding. I’m on a Mac and do not see that symbol when I hover?
Cheers,
Rick
try aiming for the spot up top and to the right of ‘Layouts…’
your cursor should change appearance as in the image below then you can drag the panel size.
still no luck?
