.TIFF Support Gone?
Hi!
Is .tiff no longer supported in v6? Is there a a preferred format for getting a 16/32bit image in Rhino?
.TIFF is still supported for both using as textures in materials etc. or output from a render or viewcapture. What is the specific workflow where it isn’t available for you?
Using the new Picture command. Getting an error “The specified file cannot be identified as a supported type”
Hello - can you post, or send us, an image?
Convert the cmyk image to rgb and you should be good to go.
Hey just following up. This was the fix. Seems like a colorspace bug.
