When using the thickness tool on rhino I find that the wireframe view doesn’t show the the 3d thickness ( see the images above) I need to be able to export the drawing as vectors to put into illustrator and without the wall thickness transferring over makes it really hard. If anyone knows a solution to this LET ME KNOW!!!
The Thickness setting is in fact just a “thickening” of the object’s render mesh - what you see on-screen in shaded or rendered views. The actual surface object is not affected, so in Wireframe, you don’t see any change.
If you need thickness in Wireframe, you will have to actually use OffsetSrf to offset your surface with some thickness.
