I tried to modify the thickness of glass in a window component, but it seems that it is not possible to set the thickness to 0 (remain always a little bit of arbitrary thickness)
Thank you
Thank you
Hi @fn_a I’ve noticed that if you type “0.00” to the glass thickness, the value is not accepted and it is restored to its previous value. But if you type 0.001, then it rounds it to 0, and you get the glass pane with no thickness. Let me know if that works for you. You should have the document absolute tolerance to 0.001m. We will revise that odd behavior.
