I’m sort of new to Rhino - I use Matrix 9 at work, so I’m very familiar with that.
But when I’m trying to use Rhino at home on my miniature laptop, I find it hard to see the lines - is there a way I can make the lines slightly bolder/thicker? I’ve worked out how to change the shade of the background and grid lines, but can’t find a way to make the working lines slightly more visible.
Is this even possible?
Thank you!
Hi Penerod,
You should be able to adjust the settings in the document properties. Make sure to change the settings for the desired view modes. Please note that it is recommended to add photos/Screenshot and source files to forum posts for clarity.
Amazing! It worked…I would’ve never have found that, I was getting a headache and irritable. Thank you so much!!
Just a clarification, although DocumentProperties and Options share the same window (in Windows Rhino), the display modes are global options, not document-specific properties.
