Rhino V7 Mac-It is nearly impossible to see what's on my screen
This is how a Rhino file looks on my screen. I would like to change a setting to change ALL the curves on EVERY Rhino file to be something more visible. And by more visible, I mean 5-10X bolder than what it is now. Thanks.
Hello - you can set a display mode to draw thicker curves, but what you are running into here is that the color value is very close to the value in the background - if you make the layer or object color darker or lighter, these curves will pop much better. Making them thicker or bolder will be less effective, imho.
Go to RHINO>PREFERENCES>DISPLAY MODE>OBJECTS
Select WIREFRAME
Scroll down to CURVES.
The default Curve Width is 1, which is very difficult to see. I set mine to 3 but YMMV.
