Thea render plugin: Some noob questions
from those PDFs
look at this image…
i’m unable to achieve that result to simulate portals
i put a rectangle in the window…
after i create a diffuse mat. with emitter feature ON, but if i set on, the invisible option from the property of the object,the rectangle disappears from the scene!
edit:
i solved…the problem was the direction of the rectangle!
