If the analysis is completed, so how to export all solutions in all generation with the best fitting value subjected to objective 1 or 2 or …?
Thanks! But the method you mentioned is just only export one individual, how do we export all the solutions with the best fitness value?
Im not sure what you mean… each fitness objective has a different fittest solution… you can change the objective number in tab 2 so that you go through the different objectives and add to the export list the fittest solution for each objective.
