The Rhino8 script editor Component does not load in Grasshopper
If we don’t run thescript editor toolsin Rhino before running Grasshopper, then the ScriptEditor component can’t be loaded in Grasshopper and this error occurs:
@eirannejad @Alain
Hi R-d,
Can you post your SystemInfo (via Rhino command line)?
To troubleshoot can you try opening Grasshopper via the Rhino command line using GrasshopperLoadOneByOne and say no to all the non-standard gh plugins. Thanks!
yes i found problem for this plugins:
and
*when remove it then grasshopper loade true
