The Reflection Alignment Change Problem
Hey guys,
When I try to allign subd object to curve, the reflection that I made using Reflect SubD tool doesn’t reflect. Could you please tell me what is the problem and how to fix it?
if you just edit it, does it reflect correctly? Meaning if you don’t align, but just drag faces or edges?
trying to determine if reflect is broken, align breaks reflect, or align is broken…
yeah, if I simly edit it does really reflect correctly. It only happens when I try to align
odd… works here-
I’m doing a point selection, then align>to curve
please run the systeminfo command and post the result.
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: tion, build 2020-12-08
License details: Stand-Alone
Windows 10.0.22000 SR0.0 or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 1-10-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.23
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-10-2022
Driver Version: 30.0.15.1123
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
ah… SR1 of rhino…
run help>check for updates… let’s get you updated to sr 17
right, thank you. Now I did it again and it didn’t work, but then I move one point only a little and it reflected lol :slight_smile: How does it work
I think your early service release (almost 2 years old now) has an incomplete feature set… please update and try it again with the updated version.
ok, thank u so much
