the plug-in wont load on macOS rhino 6.
Rhinoceros/packages/6.0/metahopper/1.2.4/MetaHopper.gha
Exception System.TypeLoadException:
Message: Invalid type MetaHopper.BottleneckNavigator for instance field MetaHopper.BottleneckerParam:navigator
Yes, Metahopper 1.2.4 for windows does not support mac. Metahopper for mac is available on food4rhino: MetaHopper | Food4Rhino.
If you’re feeling brave you can also use the prerelease version, which should be supported on mac.
metahopper.gha (269 KB)
Thanks - I will try the prerelease. Tried the mac-version from food4rhino but had no luck.
also, I only test these things on the Rhino 7 Beta mac (where it definitely does work) — I strongly recommend using that over Rhino 6 mac if you’re doing anything grasshopper based, it’s much more stable.
Metahopper in Rhino6 and Rhino7 (official) back to work - thank you!
