The edges of my surfaces look flat after adjusting the display options
Hi
I was working on some architectural diagrams. After finishing them, I decided to copy and paste them into a separate file with the final models.
Then I decided to experiment a bit with the display modes and suddenly this happened.
The edges of the surfaces look flat in every new file I create, the original file does not have that problem.
I restored to default and nothing happens.
Hi Cristóbal,
It is hard to comment meaningfully unless you post a model. It is even harder when you post contrasting images at different zoom levels.
I don’t see what you describe. Do you perhaps mean some of the edges are now a series of chords instead of smooth curves?
And when you say “every new file I create”, do you mean only files created from the one that originally had the issue or all files, including brand new ones created from a blank template?
Regards
Jeremy
it most likely is your render mesh setting, you might have set it to a very low polygon count, go to your File settings, under mesh increase the polygon count either manually or through the prepared settings.
i assume you have stored it in the template so every new file you then open will have these low settings.
this or your placed them far from the origin which deteriorates the display mesh either regardless of the settings.
Yes
And when you say “every new file I create”, do you mean only files created from the one that originally had the issue or all files, including brand new ones created from a blank template?`
Yes. When I create a new file and I copy and paste those models, the edges don’t have smooth curves
(post deleted by author)
Maybe that would be the issue..
@jeremy5 @encephalon
Thanks for the feedback. It seems the problem has been solved. I don’t know what I did, but the curves look smooth now.
